‎2004-04-26 02:27 PM
‎2004-04-26 05:43 PM
‎2004-04-26 07:18 PM
edd91 wrote:ArchiTerra.
i am making a park with walking/running tracks on it that go up and down hills etc, what is the best way to create these?
‎2004-04-26 11:25 PM
Link wrote:hey link with your first method can you run paths up hills? like the hill in my attatchment?
You can apply a material to the top of the mesh that shows the roads/driveways/paths etc, similar to the one attached. This is relatively simple to create using fills and making a texture from the 3D window. If there is enough interest I can create a tutorial on how to do it.![]()
Another way is to actually model the elements with a mesh, by copying the existing mesh and minusing the paths out of it, then pasting the existing mesh and minusing the rest out of it. This has been covered on ArchiCAD-Talk a few times, but can have unpredictable results depending on the complexity of your mesh. However it does allow you to raise/lower the paths.
Link.
‎2004-04-27 09:42 AM
Link wrote:Count me in on the interested bunch for the tutorial!
Link.
‎2004-04-27 02:20 PM
‎2004-05-06 06:12 PM
If there is enough interest I can create a tutorial on how to do it.Done.
‎2004-05-07 09:28 AM
Link wrote:Also in Tips & Tricks!If there is enough interest I can create a tutorial on how to do it.Done.
‎2004-05-07 09:42 AM
Link wrote:Sweet! Have to try this. I guess my urge for large textures taken from above will increase...may rent a small aircraft...If there is enough interest I can create a tutorial on how to do it.Done.
Please check it out athttp://archicad-talk.graphisoft.com/viewtopic.php?t=2599&postdays=0&postorder=asc&start=0
Link.
