some terrain help
Hi all,
I've encountered two things in my journey into archicad that I was hoping you can address
my first is, as you can see in the attatchment, my hill is pretty bumpy with obvious triangles, is the answer to this more nodes?
secondly,
i am making a park with walking/running tracks on it that go up and down hills etc, what is the best way to create these?
thanks
8 REPLIES 8
Link
You can apply a material to the top of the mesh that shows the roads/driveways/paths etc, similar to the one attached. This is relatively simple to create using fills and making a texture from the 3D window. If there is enough interest I can create a tutorial on how to do it.
Another way is to actually model the elements with a mesh, by copying the existing mesh and minusing the paths out of it, then pasting the existing mesh and minusing the rest out of it. This has been covered on ArchiCAD-Talk a few times, but can have unpredictable results depending on the complexity of your mesh. However it does allow you to raise/lower the paths.
Link.
Djordje
ArchiTerra.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link.
hey link with your first method can you run paths up hills? like the hill in my attatchment?
if so, a tutorial would be sweet
Link.
Count me in on the interested bunch for the tutorial!
Mats
Daniel Lindahl
G'day Link
I would be interested in that tutorial as well! What do you need for that? an aerial photo, or do you make it up in other ways?
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
Link
Done.
Please check it out at http://archicad-talk.graphisoft.com/viewtopic.php?t=2599&postdays=0&postorder=asc&start=0
Link.
Djordje
Done.
Also in Tips & Tricks!
Well done, Mr. Ellis!
Djordje
HP Omen
Done.
Link.
Sweet! Have to try this. I guess my urge for large textures taken from above will increase...may rent a small aircraft...
