Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
special snap points not showing?
When I move cursor over a line my half special snap point is not showing up?
1 REPLY 1
Check your Special Snap Point settings in the Control Box.
The Control Box may not be visible as default.
Use the Window\Palettes\Control Box menu to make it visible.
Also, this may be a graphics card driver problem.
Try upgrading to the latest driver.
