2005-12-06
09:42 PM
2023-05-25
05:02 PM
Rubia Torres
2005-12-07 08:52 AM
2005-12-07 03:56 PM
2005-12-07 05:34 PM
2005-12-07 05:56 PM
2005-12-07 10:37 PM
Zobi wrote:cigraph's archiStair
Survey says...?
2005-12-08 04:26 PM
~/archiben wrote:Agreed, archiben. I use cadimage's StairBuilder (formerly Theometric's StairBuilder) and generally like it. It has done every stair I've needed including radius, etc. The REAL power of the stairbuilder approach is that you can change one element on 1 or 100 stairs in a project with a few clicks. That is fantastic. The interface is complex but it does allow powerful customization. However, the 2d representation
(there is also cadimage's StairBuilder, but i haven't had any experience with it to be able to comment.)
my opinion: stairs are such complicated components that no object or add-on can yet provide enough flexibility to 'build' every staircase from them and have it display well in documentation
2005-12-09 02:14 PM
Zobi wrote:yes you can. it is the scaled neutral symbol. turn this off.
And it appears I can't change the font or color or size. or even make the text disappear. Is that true?
2005-12-09 05:30 PM
Zobi wrote:Cigraph ArchiStair, with StairBuilder second.
hmm. Ok. It is my understanding that there are add-ons which can be purchased which will enable AC to work like I want it to. Is there a preferred stair-construction add-on? Survey says...?
2005-12-09 06:05 PM
