KeesW
trace reference obscured by floor slab
I haven't done much drawing lately and have noticed something new in AC23. I have a surveyor's survey as a trace reference in a worksheet and have a new floor plan over the top. My slab in the new floor plan obscures the trace reference under it. I remember that not happening before. The trace reference, when selected, was always visible as a default with light greenish-grey lines. When I turn the new slab off, in layers, the trace reference appears as it should. Am I missing something or have I forgotten a setting?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
1 Solution
vistasp
Try:
View > Trace Options > Transparent Fills and Zones
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Go to post
4 Replies 4
You probably have a cover full over the slab, and it is this that is obscuring to trace view
Regards
Scott
vistasp
Try:
= v i s t a s p =
bT Square Peg
David Maudlin
Kees:
The Trace & Reference palette has a button to make Fills transparent, lower right corner.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
KeesW
Fills transparent button did it! Thank you.
