unusual window
krab-El
Hi there, I need to place a window that involves two intersecting faces. Currently, I can only position two separate windows without combining them into a single unit. The problem I'm facing is that the intersection doesn't appear accurately in the plan view. Do you have any suggestions on how I could achieve this correctly? Thanks
4 REPLIES 4
They will never be a single unit.
In the window options you should see a section for corner connections.
krab-El
Okay, Thanks
Lingwisyer
Guru
Doors do not have this issue which has been a long term wish so if you have those situations, you are stuck with a scuffed corner...
Win10 | R5 2600 | 16GB | GTX1660
Thanks a lot .It is very helpful.
