andyb:
This is why I have my Working Units set to
feet & decimal inches to
3 decimal places (as opposed to Dimensions, which typically are rounded to 1/8"): small errors, wherever they come from, are readily seen in the Tracker/Coordinates palette. I don't think the application is causing these errors, it is slightly inaccurate user input. Also, as zeropointreference mentioned, use keyboard input for accurate modeling. And watch the
Angle as you draw, very small Angle errors can be a source of these type of issues.
