walls on different stories don't join
heathldesign
I have composite walls on different stories that don't join. so i have some balloon framed walls that bridge two stories that meet another wall that is only on the second story and they don't join. i can make them join, but then the two walls on the lower story aren't joined. is there a way to work around this? i have core only selected in the structural display.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
4 REPLIES 4
Dontknow
Do you have your walls that bridge two stories set to show on all relevant stories?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
heathldesign
yes i do.
Dontknow
In that case they should join.
What you could try is to draw both walls on the same story and give the second wall a bottom and top offset so that it's actually on the second story.
ArchiCAD 25.
heathldesign
ok, i just noticed that they are joining, but in an odd way.
undefined
