‎2005-09-15
04:31 PM
‎2023-05-26
03:13 PM
Rubia Torres
‎2005-09-15 08:32 PM
‎2005-09-15 09:24 PM
Steve wrote:It's not hard. You will need to learn some GDL to do it though. You may want to spend some time with the "Object Making" book to get a handle on the language, so you can make the marker the shape you want.
The same way you would change markers on existing windows. Ctrl-A, then in window selections settings, click the Dimension Marker tab and select the new marker.
That much you probably already knew.
How to make a custom window marker is probably what you wanted to know. I do not know how to do that, but I whish I did. I hope someone will tell us if that can be done, and how to do it.
TEXT2 0,0, GLOB_ID, but there is a lot of formatting that goes along with it.
‎2005-09-19 02:15 PM
