‎2006-07-27
05:55 PM
‎2023-05-26
03:06 PM
Rubia Torres
‎2006-07-28 01:00 AM
‎2006-07-28 04:43 PM
‎2006-07-28 06:19 PM
‎2006-07-28 07:02 PM
‎2006-08-02 07:16 PM
Chadwick wrote:This seems to be the case with the Storefront objects. Under the CONTOUR LINES portion of the 2D Script within the W_Sf_macro_10 Macro, the PEN "gs_pen_2D" (the Frame Pen) has been remarked-out and replaced with "10". So you could either erase the "10!" or (as I did) create a new parameter for the contour lines and stick that in its place.
First, how do you change the pen for the wall contours in a window? I see the option to turn them on and change their line type but nothing to change their actual pen (it appears that they are pen #10).
‎2007-02-20 11:52 AM
I believe this is what the "Oversize" parameter is for: the oversize dimension should be equal to the amount of wall beyond the end of the frame (in your case, 3")I tried this but here I have line left overs on the plan view which I can not get rid of - see the attachment. Is there any remedy for this?
‎2007-02-20 04:42 PM
‎2007-02-20 05:11 PM
‎2007-02-21 09:31 AM
