zone stamp objects - where are they?
KeesW
Zones are on my mind at the moment and I want to create or alter a zone stamp. Problem is: I can't find where they are stored. I need to know because I want to put my new/modified stamp in a place where Archicad (and I) can find it. I've done a file search and can't find a zone stamp object anywhere.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
David Maudlin
Kees:
You may need to unpack the library (if it is a .pla file). In the US ArchiCAD Library 9 there is a folder named "Zones 9" with 3 zone stamps. Or you can go to File>GDL Objects>Open Object by Subtype... and then go to General GDL Object>Drawing Symbol>Zone Stamp to select a zone type object to open, even those built into the application.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
TomWaltz
The easy way is to place the Zone you want to modify. Select the Zone Marker, then select File > GDL Objects > Object Object...
Archicad will open the object editor, and you can save your modified version to your company library.
Tom Waltz
KeesW
Thanks a lot. I'll go and find them!
