Our Community
Ask questions about this community and the platform.
New Wishlist items moderated
Pato99
Hi, in the past I have spent hours creating wish list items with screen shots and edited images to get the point across.
Many of these wishes had upvotes and replies.
I feel like these have been undermined by being archived and not transferred to the new Wishlist at the discretion of GS team. I don't want to go too deep into this topic as there's already a thread Transfer-of-acknowledged-wishes-to-the-new-wish-list I've moved on and started adding in my wish listed items into the new pool.
My problem is, I just spent hours re-creating these wish threads only to have them moderated and edited by staff.
What was the crime.
"You posted 7 wishes recently, and in each one, you
  • posted links to all your other wishes, and
  • solicited users to like them and subscribe to them"
My intention was to alert people to my renewed wishlist items, all which were previously posted in the past but were starting again from scratch.
My thoughts were:
  • Adding links to each within will allow other users who like my wishes to easily find other withes I posted rather than being lost in the hundreds of wishes
  • By using the phrase "Please Like and subscribe" I was being facetious and it's unlikely to sway people either way
  • I wanted to drive interest by using excitable & friendly language to get people more involved, because if you haven't noticed upvoting is very slow even on the highly rated topics, only around 100 upvotes over many years.
  • I think without some sort of community backing barely any wished items will make the cut because it's unlikely many will make it above 10-20 votes. Not because they're bad ideas, only because there's not many voters.
  • Many wish listed items have workarounds now like Model View Options if you put a bit of elbow grease in which bogs down the list.
The moderator says it goes against policy. However I checked the guidelines and it says nothing of the sort.
Wishlist Guidelines does not state this, nor does Community Posting Guidelines
The Wishlist FAQ actually states the following, "Can I promote my wish on Graphisoft Community? A: Feel free to promote your wishes!"
**I added the links in this post because it wasn't against policy (Doesn't state anywhere that it's not allowed) but, Moderators again removed links from this thread to make a point and suit their narrative**
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
8 REPLIES 8
You left out a part from the FAQ:
"Feel free to promote your wishes! You can increase visibility by adding a link to your wish in your signature."
So, put those links in your signature. Then, if you are active on the forums, you will have many posts where people will see those links to your wishes.
Here is an example of user thesleepofreason who has several wish links in his signature:
https://community.graphisoft.com/t5/General-discussions/New-AC-Add-Ons-by-Bimdots/m-p/613196#M5313
Of course, because it's just an option of what you can do.
It's a new sentence. Doesn't say "Feel free to promote your wishes by putting them in your signature" or "Put you wishes in your signature if you want to promote them"
mthd
@Pato99, I found the first line in your signature to be quite applicable and funny too.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Hahahah I forgot about that! Too True!
Guru
100 votes over many years is probably due to the lack of visibility of anything on this forum. Unless you use saved shortcuts, even new posts in subs you are interested in are not very visible. The Wishlist being hidden under "Building Together" does not help either, even though that is the most valid place for it. Maybe if they got rid of the huge search banner, and all the Knowledge Base links on the side bar, there would be space for sub listings like you would find on any good forum.
Ling.
And now we have two different UIs for the wishlist and the roadmap... I get that the community platform limits the possibilities but for anyone wanting to increase user engagement the current setup should be unacceptable.
Wishes should be organised under main development topics not just casually labeled.
Wishes should be discussed with replies not just commented.
Wishes should be rated, just as roadmap items, not just "liked".
Guru
In memory of the old polls, who's data feels like something that has been lost to the void, yet apparently has not.
Pato99
It's done guys, updated my Signature!! 😓
