AC overriding my intersection group settings???
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-11-11
03:41 PM
‎2023-05-30
12:48 PM
Rubia Torres
‎2009-11-11
03:41 PM
I'm creating interior finishes for a residential project, so I'm adding small details like floor baseboards. To do that, I'm simply using the wall tool on a specific "interior finishes" layer, that I set with a different intersection group number than the actual walls of the house. In theory, this should prevent AC to automatically create an intersection between the real walls and the baseboards. Instead, AC keeps on changing the intersection group of my "interior finishes" back to the standard "1".
Any ideas?
Thanks!
Enrico
Labels:
- Labels:
Project Management
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-11 04:40 PM
‎2009-11-11
04:40 PM
Intersection Numbers are saved with the layer settings in your views. Changing to a new view in the View Map with a different Layer Set will change your intersection number.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-11 06:46 PM
‎2009-11-11
06:46 PM
Just wanted to add that when changing the intersection priorities in the layer settings, you will have to click "Update" on the layer combination settings in order to be locked in with the combination. And this will have to be repeated for each combination.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-11 07:23 PM
‎2009-11-11
07:23 PM
Thank you guys!
Enrico
Enrico
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-11-12 02:56 AM
‎2009-11-12
02:56 AM
ksymons19 wrote:Not any more with versions 12+.
In the layer dialogue just select the layer of concern and directly edit the values in any of the layer combinations.
Turn them on/off, lock/unlock, solid/wire frame and change the intersection priority on any or all of the layer combinations.
Saves you having to work on one layer combination at a time.
Then select another layer if necessary and repeat.
The old method of selecting the layer combination first, then setting the values in the individual lares and then pressing UPDATE still works but only allows you to work with one layer combination at a time - which is a pain when you want to add in a new layer or edit a layer in all combinations.
That's why the new method was brought in.
They both have their merrits.
One allows you to edit a single layer in all combinations and the other any layer of a particular combination.
