		2003-11-29
		01:45 AM
		2023-05-19
		12:42 AM
			Gordana Radonic
2003-11-29 07:36 AM
knacad wrote:Take a look at the attached screen shot and the one in the next message.
I'm setting up templates for our office using the IS, and I can't seem to find where I can add my own "User Defined" fields.
I saw them in some of the ones out of the box. Where did they come from?
 (I've sent in a wishlist item for this list to be alphabetized.)  If you are viewing 'All Types by Subtype', the list is sorted and grouped and things are easier to find.
   (I've sent in a wishlist item for this list to be alphabetized.)  If you are viewing 'All Types by Subtype', the list is sorted and grouped and things are easier to find. Everything in the subtype hiearchy is text.  Quite strange.
2003-11-29 07:42 AM
2003-11-29 01:33 PM
2003-11-29 01:48 PM
2003-11-29 09:11 PM
knacad wrote:Correct. The interactive schedule is a 2-way interface to the model database, so any values that you enter must be stored
Let me make sure I understand this correctly:
You can only add fields that are in the GDL objects being used in the schedule. There is no way to add a field that is only ever seen in the schedule (like maybe Jamb Detail number or Notes).
Is that correct?
2003-11-29 09:32 PM
knacad wrote:A line in the schedule will appear light grey and no fields will be editable if the element on that line is either (a) in a
More to the point, once I add fields for "Notes" or other User Defined columns, how do I add text to them?
It seems like all I can change is the ID number and materials.
