Project data & BIM
ArchiCAD 26 Schedule Merge Options The Uniform Value Display not working
Marco A
Good afternoon,
We are working on door schedules and noticed that when we merge similar doors the schedule adds the panel thickness - See picture of sample unmerged schedule and merged schedule. Choosing the Uniform Value merge option it does not work and will revert to Sum of Values when the window is closed. Has anyone else run into a similar issue?
6 REPLIES 6
So you have these settings, but they are not staying as you set them?
Correct. We can click on the Uniform Value and it will change but once we click okay and close the window the changes aren't made and the selections reverts back to Sum of Values.
When you say "We", are you working on a solo .PLN or is it teamwork (BIMcloud) where you might need to reserve the right to edit the schedule?
It's a PLN.
Is the top selection set to 'Uniform' as well?
It is.
