Project data & BIM
Building Material (ALL) values on a Property in Property Manager
davdelven
Does someone remember if there is a way to create a property within the "Property Manager" that renders the same set of values as the ones using the "Building Material (ALL)" parameter within the Schedule feature?
David Delgado Vendrell
http://www.daviddelgado.cat
i7-7820HK CPU 2,90GHz 32GB RAM
Triple Monitor 17"+25"+32" Nvidia Geforce GTX 1080
SSD+HDD, Win10 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
Jaime-airc_digital
Hi David, the "Building Materials (ALL)" general parameter is not available directly in properties.
But it is available in the IFC Property Mapping for the translators, so you can create a mapping rule for each element, see below:
Archicad 27 ARM, MacBook Pro M3 Max 128Gb, macOS Sonoma.
Jaime-airc_digital
Thanks, Jaime!
I totally forgot that workaround... even having spent hundreds of hours in the past mapping properties using the translators.
I hope a more robust harmonization and automation is implemented in the future.
Setup info provided by author
