2024-08-30
10:32 AM
2024-12-11
05:16 AM
I'm making a joinery list for a project. With Archicad's automatic tool I can display the ‘3D Back view’ of my elements. I see that it is possible to dimension them manually one by one but I would like to know if it is possible to do this automatically (I have nearly 50 different elements to dimension).
Thank you for the help.
Solved! Go to Solution.
2024-08-30 11:35 AM
Select an image and turn on the 'Add Automatic Dimensions' option.
It only gives overall dimensions.
If you want more you still have to add them manually.
2024-08-30 11:35 AM
08:00 AM
2025-01-07
01:10 PM
Hi Barry--
Is there a reason why some of the items in my schedule are not being automatically dimensioned? Please see screenshot. Seems totally arbitrary.
2025-01-06 10:21 AM
I have no idea sorry.
Try turning the dimensioning off and then on again.
Or maybe select the preview and open the 'annotation' and then OK.
2025-01-06 02:56 PM
I had the same issue and I did them manually...
2025-01-06 06:10 PM
I tried both those things...no effect. Will have to manually dimension. Thanks for your thoughts Barry.
