2023-10-19
		04:22 AM
		2023-10-23
		07:48 AM
Hello everyone.
Can you help me to configure an expression to have the information as the attach picture. I guess is a simply one, is just to have meters in "cm" or "mm" and only with two decimal houses.
The solution using Calculation Units in the Options > Project Preferences > Calculation Units & Rules Dialog, doesn’t work for me because I do not want the schedules to use centimeter.
Thanks for your time to read my issue
Solved! Go to Solution.
2023-10-19 09:29 AM
Hi
you could try the following. But need to change the datatype to text for this
STR ( Thickness / 1 m * 100; 2 )
2023-10-19 09:52 AM - edited 2023-10-19 09:52 AM
If you want your calculation to remain as a number, then you must set the data type as a number and convert the thickness in the expression to centimetres by dividing by 1m to remove the units.
Then multiply by the factor you want to increase / decrease by (100 in this case to get meters to centimetres).
You can then use this property in schedules and it will still add - but technically it has no units.
2023-10-20 05:12 AM - edited 2023-10-20 05:12 AM
@Xavi wrote:
Graphisoft should improve the label skin, so could read any element and with the option to choose which decimal and units we want. 🙂
You can't pick and choose which skin to label, but you can change the units and decimal precision.
2023-10-19 09:29 AM
Hi
2023-10-20 04:33 AM
Thank you Xandros and Barry, for the quick reply.
Did work perfectly. I appreciate the help.
2023-10-20 05:42 AM
Yes am using that label, but this one works for compositing elements and not for complex profile for example (doesn't read the thickness, and skins).
So at the moment I am using Label skins for compositing elements (walls, slabs etc..)
and for complex profile i use auto text, extracting the information from the "Profile modifiers".
Is working but, would be great to have just one tool to do this two operations.
At the moment I have another issue, because I would like to save this label as "2D Elements Label with auto text" but doesn't work.
If you could take a look att the link I would appreciate.
Thanks Barry
2023-10-20 07:22 AM
Complex profiles do not have skins like a composite does.
They may look similar in some situations, but the fills for a complex profile can be any shape and in any position, not just stacked next to each other as skins in a composite.
That is why you can not get a skin thickness for a complex profile.
