3 weeks ago
- last edited
2 weeks ago
Hi all,
This is a bug, but it has existed in Archicad for quite a while now and I'm surprised I couldn't find any info about it. The issue happens on AC26 as well
We found that the "Glass" fill orientation of Archicad default doors can be different from its elevation. Here's an example:
The "Glass" section uses a surface with horizontal line as fill.
Strangely, AC windows don't have this issue:
Another thing: CI Doors also don't have this issue, which makes me think it could be a problem of the object itself? Not too sure if this is a schedule or object issue, moderators feel free to move the topic to where it should be.
Thank you very much!
Operating system used: Windows 28.0.3
BIM Manager
DKO Architecture - HCMC
3 weeks ago
Default Archicad windows and doors do not offer any resistance to mirroring (or switching the opening side, which is basically the same thing).
Most of the time this is not detected, since I guess most people have no fills set in their glass surfaces.
But if you do: .... yeah. Utterly bad.
Could be the same issue here. I have no experience with the CI objects tho.
2 weeks ago
Yup, thanks for the confirmation. It looks like an object issue then. I reported the bug to GS
BIM Manager
