2023-03-22 02:28 AM
The elevation views in my window schedule has just gone blank. They were showing then I changed the element ID to 1 window and went to the schedule to check the update.
When i click annotate the window and the annotations are still there. I tried restarted the file and it's still blank.
2023-03-22 03:26 AM
Anything to do with the current renovation filter?
2023-03-22 04:13 AM
I don't think so. What would be the factor in the renovation filter? I created a new schedule and the same thing is happening. Maybe a bug?
2023-03-22 04:17 AM
I thought I read somewhere there is an issue if the window is set as say 'new' and when viewing the schedule you have a reno filter that hides new elements, the windows won't be seen.
I could be mistaken, but thought it would be worth checking out.
2023-03-22 07:25 AM
I checked the renovation filter and its got new elements as "show". I created another schedule and it seems to work now but I would now have to redo all the annotations...
2023-03-22 07:52 AM
I was just using 'new' as an example.
It may depend on what your wall and or window are set as.
Or I may be completely on the wrong track.
2023-03-22 07:57 AM
No worries. I understood. I checked MVOs, layers, overrides etc and can't figure out why it won't show up. I think if it was something like MVO then it shouldn't show up in the first place instead of just the elevation view disappearing.
2023-03-22 01:45 PM
We had such bugs in previous versions. It was happening because we used not latest libraries for all windows, some of windows started to disappear. But this happened only when we had Merge uniform Items turned ON.
