Project data & BIM
Hotlink and Solid Element Operations
rgarand
Hello all,
I was just starting a new project with 3 separate buldings. My plan is to have 4 files:
1 each for the buildings
1 for the site plan
I have created the site plan and hotlinked the 3 buildings into the site plan...everything comes in fine. When I goto the 3D window I notive that my solid element operations are not working. All of my walls are NOT being cut by my roofs.
Any thoughts on the problem here? I don't use hotlinks that often and do not know the ins and outs of hotlinks.
Do solid element operations not work with hotlinks? This does not seem likely...
TIA
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
6 REPLIES 6
rgarand wrote:
...I have created the site plan and hotlinked the 3 buildings into the site plan...everything comes in fine. When I goto the 3D window I notive that my solid element operations are not working. All of my walls are NOT being cut by my roofs.
TIA
Sounds like your walls and roofs are on different stories. The roofs and walls must be on the same story. When you place modules story by story the SEO relationship is broken if the roof is on its own story.
Dan K
rgarand
Thanks for the reply Dan,
You nailed it.
Is there a better way to import multiple stories without losing anything and still have the imported items updatable?
Robert J. Garand
Djordje
Use Trim to roof.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
You can also re-create the relationship after the modules are placed.
Tom Waltz
rgarand
Tom,
How do I recreate the relationship? The imported modules are grouped and locked...yet all of my layers are on and unlocked.
Maybe you can point me to the appropriate section of ArchiCAD help. I would like to read up on this info.
Thanks!
Robert J. Garand
TomWaltz
They are grouped, yes, but they should not be locked. They might act locked if Groups are suspended, because you cannot move modules unless Groups are activated.
You can suspend groups and create any SEO relationships you want.
Tom Waltz
