How to aovid the time (clock) in "issued date" field
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-11-29
09:22 AM
2022-09-28
07:11 PM
Oleksandra Vakariuk
When placing the field "Issued date" in an index the value will be showed as both date and time...
Example: "27/11/2017 13:59"
Anyway to edit this field so it will only show the date...
Workaroaunds will do as long as they´re automatically linked to the actual "Issued date"
Any tips or tricks will be appreciated.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-11-29 09:42 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-11-29 09:47 AM
I've also added a YYMMDD format field to my Issue Scheme that I can use for publishing files.
I find that these two work fine, you just need to remember to fill out the date on layouts by selecting them, going in to settings and filling out the date at the Layout Info field at the bottom. I've also put a number of 'change A, B, C, etc' fields there for my drawing index to use. Oh and sheet size as ArchiCAD will only list the paper size in mm instead of A-sizes.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-11-29 10:44 AM
Thx´s for the fast replies. The index is to be used in a company template, meaning everything has to automated, ,and no one should have to o and type the date manually, it all has to be BIM Smart, hence no personal could make the mistake of (not) typing the correct issued date when publishing revised drawings..
However shrinking column could a workaround...
Thanks for the input guys
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-11-29 11:00 AM
Adding the clock to the issue date seems like a bug to me. Who would care about that kind of detail?
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-10-13 12:32 AM
Hi All,
Did anyone ever find a solution to this problem? I am also trying to work out a way to How to avoid the time displaying in "issued date" field
Ben
AC 22/23
Ben
ArchiCAD 23 -amp; 26
MacOS 12 - 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-05-24 07:24 PM
Bumping this. This seems like a basic feature, along with the option to convert the mm of the format to A3, A4 etc. I considered making my own expression in the property manager for this, but alas - the issue date or even the system date is inaccessible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-06-27 03:21 PM
Also bumping this - theres been several threads about this dating back many years. Time for this to be fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-07-21 09:17 AM
Hey all.
Still no resolution to this issue? 🤞
Hoping to find a solution to this to avoid adding custom items to the scheme.
Regards,
John Carlos
AC25 | iMac 2019
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-10-13 03:18 AM
Re-bumping the bump!
