How to avoid the time (clock) in "issued date" field
Hi guys.
When placing the field "Issued date" in an index the value will be showed as both date and time...
Example: "27/11/2017 13:59"
Anyway to edit this field so it will only show the date...
Workaroaunds will do as long as they´re automatically linked to the actual "Issued date"
Any tips or tricks will be appreciated.
Cheers
15 Replies 15
If you don't get a better response you could always try reducing the width of the column in the schedule.
Erwin Edel
I've added custom date fields to the Layout Info Scheme for this reason (and to be able to just set whatever date I want). You can shedule them, use them as autotext same as the system date + clock thing.
I've also added a YYMMDD format field to my Issue Scheme that I can use for publishing files.
I find that these two work fine, you just need to remember to fill out the date on layouts by selecting them, going in to settings and filling out the date at the Layout Info field at the bottom. I've also put a number of 'change A, B, C, etc' fields there for my drawing index to use. Oh and sheet size as ArchiCAD will only list the paper size in mm instead of A-sizes.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Hi Guys.
Thx´s for the fast replies. The index is to be used in a company template, meaning everything has to automated, ,and no one should have to o and type the date manually, it all has to be BIM Smart, hence no personal could make the mistake of (not) typing the correct issued date when publishing revised drawings..
However shrinking column could a workaround...
Thanks for the input guys
Erwin Edel
Shrinking will not work, as far as I know. Even if you turn off 'wrap text', there will be '...' for the missing text.
Adding the clock to the issue date seems like a bug to me. Who would care about that kind of detail?
www.leloup.nl
BenATA
Hi All,
Did anyone ever find a solution to this problem? I am also trying to work out a way to How to avoid the time displaying in "issued date" field
Ben
AC 22/23
Ben
ArchiCAD 23 -amp; 26
MacOS 12 - 13
canvea
Bumping this. This seems like a basic feature, along with the option to convert the mm of the format to A3, A4 etc. I considered making my own expression in the property manager for this, but alas - the issue date or even the system date is inaccessible.
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
Bogus
Also bumping this - theres been several threads about this dating back many years. Time for this to be fixed.
JCCARLOS91
Hey all.
Still no resolution to this issue? 🤞
Hoping to find a solution to this to avoid adding custom items to the scheme.
Regards,
John Carlos
John Carlos
AC25 | iMac 2019
GMcBeth
Re-bumping the bump!
