Invisible toolbox elements - archicad 10 edu int
hello,
recently i switched to archicad 10 (edu international) from archicad 9.
and some elements of palettes like toolbox or coordinates are invisible,
i can click them, they work, but i can't see what icon i'm choosing.
Can anybody help me?
screenshots below
(i work on win xp pro, all open GL 3d elements in archicad work properly)
18 Replies 18
Try switching work environments. It might also be a video card/driver issue.
I have the same problem
"Try switching work environments" means what exactly ?
regards
Jean-Luc
Djordje
What are your video cards?
Jean Luc, you mentioned Intel. Is it integrated? That does not bode well ... and the memory is then deifnitely shared.
What are the computer specs? Memory, video memory? If the machines are branded, which exact models are they?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Archicad 10 work out well on
Laptop:Inspiron 1100
Intel(R) Celeron(R) 2.20 Ghz
L2 128Kb
RAM:510Mb
Intel(R) 82845Gl/GE/PE/GV
driver 6.14.10.4342
1024x768 with 32 bit color depth
BUT NOT ON
Dell dimension 2400
Intel(R) Pentium (R) 4 CPU 2.80Ghz
L2 512Kb
RAM:1022Mb
driver 6.14.10.4342
Therefore I doudt that the problem is related to the video card
or the driver. Moreover so far Archicad 8 and 9 did work on both machines without problem.
regards
Jean-Luc
Aaron Bourgoin
Does this post on the US Support FAQ help?
Problem described:
crash during the splash screen loading in AC10 on a Dell Precision 390, "The program loads for about 3-4 seconds and crashes"
Resolution:
"crash during the splash screen loading in AC10 on a Dell Precision 390 was caused the presence of wxvault.dll. The solution is to remove the EMBASSY software"
Another user reports:
Uninstall Dell Embassy Trust Suite by Wave Systems
it blocks Wibu-Key Software due to incompatibility with 16-bit application.
Apparently, this is related to a thumbprint security software, and the IT
person had encountered this problem before, albeit for another program. I
do not have this security reader installed, but I believe the computer was
shipped with software to accommodate it. Please pass on this information to
any and all who can benefit from this information.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.31 Mac
MacOS Tahoe 26.5
the last post does not help (at least me).
May I ask if "adam eee" solve the problem meanwhile ?
Jean-Luc
Dear all,
I want to add that peolpe from graphisoft in Istanbul are not able to answer me. They are more or less arguing that the problem come from
my computer. Interesting.
From my point of view it is a bug that may occur any time with window xp or other. When you have two similar computer with
the same config and the same antivirus (yes it could be a virus...though attacking only archicad 10 is unlikely), for me it is a bug which may spread whenever the config of the computer change (update of windows for instance).
So it would be nice to have a proposal to solve this issue especially when
you have a license like me since Archicad 8 (as we say in France BORDEL !)
is there anyone who has an email from a computer scientist in graphisoft, may he or she will be able to answer me.
Regards
Jean-Luc
Djordje
Both laptops that you have mentioned have the minimum configuration - even below minimum in the case of Inspiron that works (!)
I strongly suspect that the guys at local support are right - something in your Dell does not agree with 10. The lack of memory does not help ... whatever it is.
Can you try on another machine, maybe a desktop, or a Mac? Is it possible to expand RAM on any of the laptops?
Djordje
HP Omen
Hello Djordje,
I already tried on another computer.
(ah ! the dell dimension is not a laptop but a desktop)
A Dell (again) Oplitex
Intel(R) Pentium(R) 4CPU 3.00 GHz
L2 cache: 1024
Memory: 1022Mb
Video card: Intel(R) 82865G Graphic controlled(still integrated)
It works !
I know how that will finish :new installation of windows xp !
I suspect a problem in the registry and a DLL problem.
if someone like "adam eee" encountered the same issue
you can imagine that many others will too
(no new about "adam eee"... would be nice to know his computer
config to compare)
