‎2016-06-06
05:19 PM
‎2023-05-30
12:38 PM
Rubia Torres
‎2016-06-06 08:04 PM
‎2016-06-06 08:06 PM
alemanda wrote:
yes ... it seems very strange ... but this is how it works.
Layer combinations seem to be by-name associated ... so you change the name of the layer combo and you lose the association in all the views ...
‎2016-06-07 06:10 AM
‎2016-06-07 08:46 AM
‎2016-06-07 03:39 PM
Erwin wrote:
It is why we have a long and comprehensive list of layer combinations in the template we use.
And they are the only template 'attribute' so to speak we freely modify on projects to suit our needs (hiding/showing layers as needed in combinations).
The association isn't truly by name either, I think. I remember trying to switch two layercombo's around by renaming both in one edit, didn't work as I recall.
‎2016-06-07 03:44 PM
‎2016-06-08 02:58 PM
rob2218 wrote:I tried this in ARCHICAD 19 and it works for me. View Settings identify Layer Combinations by Name so what you are describing should work, it does for me.
So...let's say you have a layer combo named "Floor Plan Walls A" and you have another layer combo named "Floor Plan Walls B".....and assign viewmaps to these layer combos. Then you rename the 2nd layer combo to "Floor Plan Walls C" and rename the first layer combo to "Floor Plan Walls B", you're telling me I the viewmaps won't accept it being renamed back to its original name again?
