Layer Combinations and ViewMap Associations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-06-06
05:19 PM
2023-05-30
12:38 PM
Rubia Torres
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
- Labels:
Project Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-06 08:04 PM
Layer combinations seem to be by-name associated ... so you change the name of the layer combo and you lose the association in all the views ...
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-06 08:06 PM
alemanda wrote:
yes ... it seems very strange ... but this is how it works.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-07 06:10 AM
So far it is just marked to be fixed in a future release.
The same thing happens when you rename pen sets, model view options, renovation filters and now in 20 the new graphical overrides.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-07 08:46 AM
And they are the only template 'attribute' so to speak we freely modify on projects to suit our needs (hiding/showing layers as needed in combinations).
The association isn't truly by name either, I think. I remember trying to switch two layercombo's around by renaming both in one edit, didn't work as I recall.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-07 03:39 PM
Erwin wrote:
It is why we have a long and comprehensive list of layer combinations in the template we use.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-07 03:44 PM
We just adjust the 'main' layercombo's as needed. We have them for different scales/phases and the template is setup with seperate view maps/clones for all of them, it works relatively painless this way.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-08 02:58 PM
rob2218 wrote:I tried this in ARCHICAD 19 and it works for me. View Settings identify Layer Combinations by Name so what you are describing should work, it does for me.
So...let's say you have a layer combo named "Floor Plan Walls A" and you have another layer combo named "Floor Plan Walls B".....and assign viewmaps to these layer combos. Then you rename the 2nd layer combo to "Floor Plan Walls C" and rename the first layer combo to "Floor Plan Walls B", you're telling me I the viewmaps won't accept it being renamed back to its original name again?
But I agree, these View Settings should be identified by some internal index number, not but Name so changing Names would not cause these issues.
