‎2014-08-04
02:25 PM
‎2023-05-25
06:33 PM
Rubia Torres
‎2014-08-04 02:34 PM
‎2014-08-04 02:52 PM
laszlonagy wrote:I did mention that the hotlink Delete function is grayed-out. SO if it was that easy I would have done it...
A guess: by deleting the hotlink modules and then their linked libraries will also be removed from the project?
‎2014-08-04 03:38 PM
‎2014-08-05 11:56 AM
‎2014-09-01 03:06 PM
‎2014-09-01 08:40 PM
Erwin wrote:This is the only way to get rid of those pesky grey hotlinked libraries.
Modules can have embedded libraries, even if the elements aren't used in that module. You will have to open te modules, delete the embedded library parts, save the module, refresh hotlinks, refresh library and pray for a miracle (ok, maybe not the last part anymore, but we don't use embedded libraries as a rule in our office, still using the old method of project library folder on our server... mainly because of this problem with hotlinked modules and getting duplicate embedded items).
‎2014-09-02 06:21 AM
‎2014-09-02 06:40 AM
‎2014-09-02 09:03 AM
