BulldogBen
Minor inconsistency in section and elevation icons
As a new user trying to understand exactly what I'm seeing in the Navigator, I think I've found a minor inconsistency. In the clone folders the icons for section and elevation differ by a horizontal line, but the icon is the same for sections and elevations even in a new project:
Hopefully it's clear from my screenshots above, and that fixing this will help reduce cognitive dissonance for a few new users?
(Unless I've missed something and am making a total **beep** of myself of course)
1 Solution
James B
As we are working around this area, I've created a report already.
Thanks for highlighting this issue.
James Badcock
Go to post
9 Replies 9
That is a keen eye to spot that.
I can confirm in 29 that the wrong icon is used for the cloned elevation folder.
It shows a section icon with a cut line for the ceiling.
Certainly not the case in version 25.
I am not sure what version it broke in, 26, 27 or 28.
Fortunately it does not affect anything other than aesthetics.
CosminF
AC27 has the same inconsistency. So that may narrow it down - from which version it appeared.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
BulldogBen
Your screenshot is so much clearer than mine too!
BulldogBen
Thanks for your input everyone.
Even though it's minor I think the only acceptable fix is a tweak in the next Hotfix.
Could you report this to your local reseller?
Or report it at https://support.graphisoft.com/hc/en-us/requests/new
James B
James Badcock
Thank you @James B
BulldogBen
I appreciate that as the busy-work of copy and pasting issues from one place to another isn't much fun, so I appreciate you doing it for me.
AllanP
The error starts at Archicad 26
at Archicad 25 it is still correct
Regards,
AllanP
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
