2026-03-09 08:23 AM
As a new user trying to understand exactly what I'm seeing in the Navigator, I think I've found a minor inconsistency. In the clone folders the icons for section and elevation differ by a horizontal line, but the icon is the same for sections and elevations even in a new project:
Hopefully it's clear from my screenshots above, and that fixing this will help reduce cognitive dissonance for a few new users?
(Unless I've missed something and am making a total **beep** of myself of course)
Solved! Go to Solution.
2026-03-09 04:08 PM
As we are working around this area, I've created a report already.
Thanks for highlighting this issue.
2026-03-09 09:56 AM
That is a keen eye to spot that.
I can confirm in 29 that the wrong icon is used for the cloned elevation folder.
It shows a section icon with a cut line for the ceiling.
Certainly not the case in version 25.
I am not sure what version it broke in, 26, 27 or 28.
Fortunately it does not affect anything other than aesthetics.
2026-03-09 10:05 AM
AC27 has the same inconsistency. So that may narrow it down - from which version it appeared.
2026-03-09 11:10 AM
Your screenshot is so much clearer than mine too!
2026-03-09 11:11 AM
Thanks for your input everyone.
Even though it's minor I think the only acceptable fix is a tweak in the next Hotfix.
2026-03-09 02:16 PM
Could you report this to your local reseller?
Or report it at https://support.graphisoft.com/hc/en-us/requests/new
2026-03-09 04:08 PM
2026-03-09 04:16 PM
Thank you @James B
2026-03-09 07:26 PM
I appreciate that as the busy-work of copy and pasting issues from one place to another isn't much fun, so I appreciate you doing it for me.
2026-03-24 12:09 AM
The error starts at Archicad 26
at Archicad 25 it is still correct
Regards,
AllanP
