Tuesday - last edited Wednesday by Laszlo Nagy
So I have something weird going on that I can't seem to figure out. It's happening to all of my schedules. I have all of the headers set in Bold font, but once I click out of the cell the Bold font disappears and it goes back to regular font. Is there a setting that's overriding it or something that I might've over looked?
Operating system used: Windows 10
Solved! Go to Solution.
Friday
There may be other fonts within the family of "Stylus BT", that handle the bold status instead. When you open the font selector, are there multiple options under or next to Stylus BT?
Friday - last edited Friday
Here's some pictures for reference.
Friday
Friday
Stylus BT is a single typeface font style. If you want to use bold charecters then you need to choose a font that has several different typefaces within the parent font name. Hope this helps.
Ditto above... and that you might want to replace Stylus BT with a newer font such as Tekton Pro which is similar ... if it is available to you (installed along with dozens of others with Adobe apps). It's based on the earlier Tekton...
https://fonts.adobe.com/fonts/tekton
yesterday
Ah yes, that's the issue. I thought I had it working before, but it must have been a different font and never noticed it till now. Thanks for pointing that out!
