Project data & BIM
Schedules (Window Door, & Skylight)
ELEVATE
Does anyone have any Idea why the dimensions in the following schedules are not consistent or some don't even appear?
1. The Door Schedule Looks Great dimensions text & line same color and dim. font same size. (want I am after for the other (2) schedules)
2. The window schedule shows the dimensions but the lines are black and the font is blue. And the fonts vary in size (WOULD LIKE DIM. TEXT @ FONT TO BE BLUE & DIM FONTS SAME SIZE.)  Is there a way to edit all the dimensions at once OR do I have to do each one separately?
3. The skylight schedule doesnt even show dimensions, even though the dim check box is marked. Any Idea why?
 Thanks
em used: Windows 23H2
Operating system used: Windows 23H2
DMD
Scott Bowden
To fix the dimension styles: Try
1. Return to the main floor plan view of Archicad
2. Select the dimension tool and either eyedropper a dimension string you like, or calibrate it to look exactly how you'd want it in the schedule (fonts, pens, witness lines etc)
3. Go back to the schedule view and turn off automatic dimensioning checkbox, then turn it on again.
They will all reappear with your new presets and stay that way until you uncheck the box again.
We have an issue where the automatic dimensions in the schedule view are not showing, by selecting Annotate for a particular door or window they re-appear in the Annotation window. Closing the annotation window back to schedule view they disappear. We have tried multiple layers-all on, model views and graphic over-ride combos but no success.
Yes, this has been an issue for quite a while.
Please read the following post for a workaround:
https://community.graphisoft.com/t5/Collaboration-with-other/Annotations-missing-from-schedules/m-p/...
Setup info provided by author
