a month ago
I’d like to invite you all to try a new, totally free (no hidden fees or costs whatsorever) Archicad add-on available here: https://www.bimquants.com/lite/index.html
This is the Lite version of BIMquants system, and it will be free forever. I even intent to make it open source someday, available on github.
It works inside Archicad no connection to internet or external apps needed. It does not call home. It also works in demo version of AC (you can create and export your quantity takeoff data even in read-only projects and than re-import the data later again).
Currently it only works in AC29, on Windows. There will be Mac version and support for older AC's too.
Even though it’s still in beta, the functionality is already complete and ready to use. I encourage you to download it, give it a try, and see how it fits into your workflow.
If would really like some feedback, so if you come across any bugs or issues, please report them at info@bimquants.com — your feedback will really help improve the tool.
Looking forward to hearing what you think!
Operating system used: Mac Intel-based
a month ago
- last edited
a month ago
There was a question asked if BIMquantsLITE addon supports composite elements and by-skin quantities. It does - you can extract skin's area and volume for each individual skin.
When you click on a composite element, go to add qty, click on formula button, there will be a popup with quantities that can be extracted from an element.
Select SkinVolume() and a new dialog will appear, which will enable you to pick individual
skin.
Select a skin and click "Select" button. Formula will appear in the Edit Qty dialog.
4 weeks ago
Hi, i have tried your plugin and works well for small projects. Good work.
i have just one question - will the plugin support complex profiles too- for walls, columns,..,?
4 weeks ago
This was added in the last release iteration. You can extract profile's region area and volume.
Check the formulas section of the manual https://www.bimquants.com/lite/manual.html#formulas-functions
4 weeks ago
Hi,Your add-on looks very interesting. Is it available for v28?
4 weeks ago
Not yet but getting there.
It will be available for AC v27 and newer.
4 weeks ago
Great I look forward to trying it out when available. How long do you think it will take ?
4 weeks ago
It is already available.
Please download the apx from https://www.bimquants.com/lite/#download and report back if it works for you.
4 weeks ago
Perfect thank you. I'm away for a couple of days. I'll have a look when I return and let you know how I get on
Tuesday - last edited Tuesday
I tried the free version for AC27 ad it's super! Easy and fast ... in line with the Archicad spirit!
With few improvements it will be a killer addon for the everyday work!
Love it!
