2006-12-15
01:05 AM
2023-05-26
09:05 AM
Rubia Torres
2006-12-15 08:02 AM
2006-12-18 11:10 PM
Matthew wrote:I tried re-publishing all the external modules from 10 and redirecting the hotlinks to the new AC10 modules, and it makes no difference.
Is it the same saved over the network and locally?
2006-12-19 07:18 PM
2006-12-19 08:37 PM
Erika wrote:It is not the libraries (all are SE9), it is the automatic hotlink update every time it opens or saves. I can't find a setting to control that.
I have found some of the earlier AC library parts quite slow in AC10.
2006-12-19 09:38 PM
Ignacio wrote:It's under "Data Safety" in your Work Environment.Erika wrote:It is not the libraries (all are SE9), it is the automatic hotlink update every time it opens or saves. I can't find a setting to control that.
I just tried breaking the hotlinks and the Save time goes from some 2 minutes (be it networked or local) to some 6 seconds.
2006-12-20 12:40 AM
TomWaltz wrote:I want to kiss you.
2006-12-20 06:42 AM
Ignacio wrote:I think we should just be friends.TomWaltz wrote:I want to kiss you.
