We value your input!
Project data & BIM
Surfaces need more parameters.
Titiriga
This is more of a rant than it is a question but here it goes.
There are 3 types of schedules available in ArchiCAD, Elements, Components and Surfaces. The first 2 are deffinetly wider in scope, but Surfaces has one important relevant parameter, Exposed Area.
This parameter is usefull, but a major drawback is that the Surfaces themselves lack in propertyes to be listed. Most of a Surface's properties have to do with how it looks or how it's rendered in 2D and 3D. For listing, the only relevant property is its name. Surfaces dont even have a ID box, let alone a description box or the posibility to add other information to them or to assign a Classification system to them or Properties. I'm shure a ID box isn't so hard to implement, it dosen't even have to be a new version of ArchiCAD, it could just be a update, a fix, something like that.
Sorry for the outburst.
4 REPLIES 4
You should make a wish in the Wishlist so people can vote for it and if it gets enough votes within a specific amount of time it will be submitted to Graphisoft:
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist
I've never submited a wish before so I'm not shure if I'm doing something wrong, but the submit a wish button is greyed out and I also cant vote on other wishes. Any ideas why? Thank you.
The FAQ's might help.
https://community.graphisoft.com/t5/Our-Community/Wishlist-Frequently-Asked-Questions/ta-p/603212
I've submitted my wish using the office account. I couldnt help myself and added a few other wishes.
Just for extra visibility, here are links to them.
1 .More parameters for Surfaces
https://community.graphisoft.com/t5/Wishlist/More-parameters-for-Surfaces/idi-p/637922
2.Find&Select should include Home Story as a search parameter
https://community.graphisoft.com/t5/Wishlist/Find-amp-Select-should-include-Home-Story-as-a-paramete...
3.Renovation tool needs to be updated.
https://community.graphisoft.com/t5/Wishlist/Renovation-tool-needs-to-be-updated/idi-p/637926
Thank you.
Setup info provided by author
