Project data & BIM
What happened to EDIT SELECTION SET ?
Steve Jepson
I used this function a lot in the with layers management. For example when I want to designate a layer for everything I have selected.
I don't see it any more in ArchiCAD 25 where it used to be. Is it gone or just in a different place?
4 REPLIES 4
Eduardo Rolon
In macOS its still in the same place
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Steve Jepson
Thanks. It still where I has always been in Windows too. I was used to it being in my Edit menu. It must have been moved somehow from my Work Environment Profile.
The CTRL+SHIFT+T keyboard shortcut still works, even though its button is no longer displayed in the Info Box.
I also have it set up as a tool in one of my tool bars.
Not sure if it is in a standard (default) toolbar, I have a fairly customised set.
