2024-04-13
04:30 PM
2024-04-16
12:52 AM
how can i create a label for pipe diameter in mm without decimals?
Operating system used: Windows 10
Solved! Go to Solution.
2024-04-14 09:00 AM
Like this
2024-04-14 02:16 AM
What are the settings you are using on the label?
There would be an expression you could use to remove the decimals. But I think it’s probably better to adjust the settings of the label to not show the decimals.
2024-04-14 09:00 AM
Like this
2024-04-14
07:10 PM
2024-04-16
12:54 AM
its an autotext label
2024-04-14
07:14 PM
2024-04-16
12:54 AM
i dont understand the solution but it works
