Project data & BIM
diameter in mm without decimals
Guillermo1
how can i create a label for pipe diameter in mm without decimals?
Operating system used: Windows 10
Yves
Like this
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
4 REPLIES 4
scottjm
Mentor
What are the settings you are using on the label?
 There would be an expression you could use to remove the decimals. But I think it’s probably better to adjust the settings of the label to not show the decimals.
Yves
Like this
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
its an autotext label
i dont understand the solution but it works
Setup info provided by author
