ā2006-03-02
08:57 PM
ā2023-05-26
09:05 AM
Rubia Torres
ā2006-03-02 09:01 PM
ā2006-03-02 09:07 PM
ā2006-03-03 10:16 AM
ā2006-03-04 02:31 AM
Djordje wrote:Ofcourse, trim to roof is one of the first tools for this kind of job...but...my intention of using solid element operations for trimming walls to roof was the fact and advantage that I could freely change the roof pitch and plate heights without having to re-trim. Unlike when using the "trim to roof"....when you change pitch, change top plate heights....well your just going to have to undo trims and re-trim it again. If only the trim to roof had the function to keep its trimming properties regardless of changes (similar to how solid element operations work). Maybe this could be a new feature in the new versions/upgrades to come. Definitley a plus.
Did anyone say Trim to roof?
ā2006-03-04 08:35 AM
ā2006-03-04 08:55 AM
Thomas wrote:Wait a minute Thomas, You "can" remove your operators and still come out with your resulting "object". You simply hide your operators in a hidden layer and there you have it...then save your object.
I think Trim to roof is fine as is - it's an almost permanent cut operation. The problem is that it's so limited, to just roofs.
What we need is a way to "fix" SOEs. A "Make Permanent" button would let us cut out complex forms with SOEs, and then remove the operators and use and re-use the resulting object without the issue this thread started with.( I'd save the operators as a module anyway).
ā2006-03-04 03:34 PM
ā2006-03-04 04:44 PM
ā2006-03-04 06:03 PM
junior wrote:You are talking relationships now ...
And yes, Trim to roof is fine...but...could be better. Imagine being able to change roof pitches and top plate heights, and all the while, the walls under those roofs that were trimmed to that particular roof kept its trimming "rules"...to stay trimmed up to that roof, no matter if you change its pitch or top plate height, it would always be cleanly trimmed up to that roof. (just like how SOEs function).
