2006-09-03 09:03 PM
2006-09-04 05:25 AM
jdk wrote:You can post a screen shot.
Hello,
Step 4.1 of the ITC fails on a new project. Instead of a door, I get a gallery. That's right, a gallery... I start with an empty sheet, I make a slab, then walls with the magic wand. The result, at this step, is a closed building, including an additional slab for the roof. I stress this, because the roof really surprised me. Then I add a door, just like in the ITG, and as soon as I click to center it, I get a gallery, all the way to the other side of the building, where it ends with a hole. Is this a standard feature? What am I doing wrong?
I wish I could post the .pln, but the website does not allow it.
Bob
2006-09-04 09:01 AM
2006-09-04 10:52 AM
2006-09-05 04:33 AM
2006-09-05 09:07 AM
2006-09-05 11:24 AM
jdk wrote:Are you sure you switched to the Straight Wall Geometry Method and you still got a Polygonal Wall after using the Magic Wand on the other element to create the Wall?
Barry, I reached the same conclusion last night, but did not manage to solve the problem. I repeated the same steps over and over again; at times, I get proper walls around the slab, but most of the times I get one big wall. I'll try again this night, with extra care, to see if it is a bug or a fault of mine.
Bob
2006-09-05 12:40 PM
2006-09-06 05:21 AM
jdk wrote:Try pressing the scroll wheel and holding your left mouse button, with and without the Shift pressed ...
[Another peculiarity is the 3d viewing buttons. Why using nine buttons (five zoom, panorama, orbit, explore and autoscale), instead of a Google-earth-like navigation system? :-]
2006-09-06 11:04 AM
