Installation & update
Archicad 22 Dark shade on trace refrence
Hello everyone,
We`ve recently switched to AC22 and we also migrated some projects from AC 20 and 21. In both cases when i set up a trace refrence and decrease the transparency/visibility of it it turns into a dark shade of that color. The fills become a darker shade of grey. Previously it became more white-ish or more transparent. If i decrease it too much, its just a grey fill.
It even happens with new projects.
Is this a new "feature"?
I`m using AC 22-4023 NED, on MacOS Mojave 10.14.2.
7 REPLIES 7
Erwin Edel
Check in with Kubus (the reseller in NL for us) for possibly a quicker answer, but if possible try on a system still on High Sierra, as there are some issues with Mojave and Nvidia GPU hardware accelaration (no drivers available for Mojave still).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thanks Erwin.
That what i usually do, but this time i said i should take the matters in my own hands. I`m sick of calling the good guys at kubus for every small thing.
I`ve tested it on High Sierra. it does the same thing.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
This is a known issue on macOS (fix #244622), but it was fixed in the latest update (build 5009). Please install the latest update, and see if it helps.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Erwin Edel
Regards,
Sadly 4023 NED is still our latest version, since 5009 is still awaiting approval from GS I suppose?
www.leloup.nl
Windows 10 Pro
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Nope, it is out. Here's a link to it:
https://www.graphisoft.com/downloads/archicad/updates/?localization=NED&type=FULL&version=22
Regards,
GRAPHISOFT
Erwin Edel
I guess something somewhere still needs a final nod of approval, since 'check for updates' still shows my AC22 up to date with 4023
www.leloup.nl
Windows 10 Pro
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
You are right, I checked, Check for Updates wasn't activated yet. Took care of it, it should work now! : )
Regards,
GRAPHISOFT
Learn and get certified!
