Find the next step in your career as a Graphisoft Certified BIM Manager!
Installation & update
Crashes each time when I open an existing file
euzagum
Hi everyone,
After installation of Archicad 25 (4013) can't open any existing file. I can make a new one, but every time when I try open an existing one there is an issue. MasOS 12.4,
Version:               25.0.0 v1 RUS (4013) (25.0.0.4013)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-08-31 20:47:53.7980 +0300
OS Version:            macOS 12.4 (21F79)
Report Version:        12
Bridge OS Version:     6.5 (19P5071)
Time Awake Since Boot: 110000 seconds
Time Since Wake:       28860 seconds
System Integrity Protection: enabled
Crashed Thread:        0  CrBrowserMain  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000db287846
Exception Codes:       0x0000000000000001, 0x00000000db287846
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [33337]
Please help..
1 REPLY 1
First, update your system. You should be running macOS 12.5.1 now and the release version for Russia (RUS) is build 5010, released 16 May 2022.   Install both of those and try again.
If you still have issues, crashes can really only be analyzed by technical support - so you would have to contact the distributor for your country.  Be sure to allow the Archicad Crash Reporter to gather data and submit the report... and make a note of the Crash ID for when you contact support.  (The Apple crash log you attached has no useful information.)
P.S.  There is a Preview version of AC 25 Update 6000 available to download for certain countries which addresses some crashes.  RUS is not an edition that is available for the Preview. If you have the INT version installed, you could update that and test.  The release for all countries will be made this fall.
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.5, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
