Installation & update
Error Code 2002
Tom Krowka
Am trying to do a sun study and am getting error code 2002, "Can't generate the movie". It worked fine last week; however I did install V16 in the meantime. Am still on V15 PLN however. That shouldn't have anything to do with it,should it?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 REPLIES 2
having the same problem- did you ever find a solution? Thanks!
Andrew, AC15, win7
Tom Krowka
That was a while ago. But if I recall, it was a problem with the difference in rendering engines between the two versions. I think the problem went away after I opened the older version in the newest version.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
