2010-09-01 05:02 PM
2010-10-19 11:15 AM
2010-10-19 12:13 PM
2010-10-20 11:47 PM
2010-10-25 10:33 AM
2010-10-29 11:15 AM
Marton wrote:Hi Marton,
Here you can find an article how to set up TW on Mac network without DNS server:
http://www.archicadwiki.com/Teamwork/MacConnection
Marton wrote:I want to stress the point that the problem is not that "Library is not found for one Teamwork user, but it is available for others". ALL Teamwork users cannot see/update libraries. Right now the only way to work, is to copy the L-2 folder from the only user that has the objects loaded, and copy it to the other users. But still none can refresh their library local copy.
To troubleshoot existing library problems see this page:
http://www.archicadwiki.com/Bugs/Teamwork/LibraryNotFound
2010-12-08 06:34 PM
2010-12-09 04:55 PM
2010-12-09 10:05 PM
vfrontiers wrote:I think you just save them as Embedded objects. They become part of the Project's embedded library. You send the changes and others receive changes and the library part should be there in their AC copy in the Project's embedded library.
2. What is the proper protocol to create project specific objects and have them available to all members of the team?...
2010-12-09 10:38 PM
laszlonagy wrote:So two things wrong with that...vfrontiers wrote:I think you just save them as Embedded objects. They become part of the Project's embedded library. You send the changes and others receive changes and the library part should be there in their AC copy in the Project's embedded library.
2010-12-09 10:41 PM
vfrontiers wrote:So I guess the real "question" here is HOW do I get it to show up after AC tells me it's not there... BTW.. not there means I did a search for the part and it was not found... And Browsing thru the embedded library does not find it either..
1. Part did NOT show up when signed in from my other computer... (it's only 2 feet away from the server!😉
