Teamwork & BIMcloud
Error message not enough space when installing BIMcloud
Achille Pavlidis
I was going to install a new instance of BIMCloud Basic 2023.3 in order to migrate to AC27.
When starting the Installer I got this message:
Note that I have more than 20GB free.
What to do???
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
Questions:
Do you have any external drive?
If yes, can you unmount it while running the Archicad Installer?
Do you have any mounted dmg?
I think you mount the Archicad Installer dmg. So, please mount it, copy the Installer app from it to somewhere, then unmount the dmg and try to run the copied Archicad installer.
Do these steps help?
13 REPLIES 13
Istvan Lengyel
Unfortunately this is a known error of our Installer "engine".
In this case, you should restart the computer. After the Installer can be run, it will not show this error.
Ferenc Szalontai
We have registered the bug in our system. We will try to fix it as soon as possible.
Achille Pavlidis
Any news on the question?
We cannot install Archicad 27 because of this pretty serious error!
Even after a restart as Istvan suggested?
yes
even after several restarts
In this case:
The installer should be run from the Terminal with this command:
…installer….app/Contents/MacOS/installbuilder.sh --debugtrace debug.txt
And step to the dialog, when Installer shows the error message about the disk space.
And the created debug.txt should be sent to us.
I can send it to the company, who the develop the Installer Maker "Engine".
They can examine this debug file.
Achille Pavlidis
I have the file
Where do I send it?
Can you upload to the link below?
MacInstallErrorDebugFile
Achille Pavlidis
Can't sign in
Other method?
