Teamwork & BIMcloud
TW creating multiple DWG Translators when Publishing
Eduardo Rolon
Any idea?
undefined
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
4 REPLIES 4
Eduardo Rolon
Hotfix 02 didn't fix this.
undefined
AC28 US/INT -> AC08
another Moderator
schagemann
we just had this happen to us and we are now trying to find which directory has the wrong permissions - did you ever manage to find a fix for this… ?
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
Eduardo Rolon
Nope.
AC28 US/INT -> AC08
another Moderator
Csaba Kezer
The translators getting duplicated is clearly the sign of ArchiCAD not having the permission to overwrite the original instance. You should check whether all folders in the path to the mounted volume allow full access for the clients:
- Right click on the Folder
- Get Info
- in Sharing & Permissions section change the permission to "Read & Write" for everyone.
Hope this helps,
Csaba
Csaba Kézér
Director, Global Customer Support
