Teamwork - XREF Manager - Bind grayed out
Hi there,
I tried to attach a dwg and bind it to Arhicad 18. Normally it worked fine but in a teamwork the bind button it's grayed out.
I have lead architect role in bim server and reserved all.
If you have any ideea how to bind it please share.
Thank you!
4 Replies 4
This is just a guess:
The screenshot says the XREF is loaded. But I think it should be attached, meaning it needs to be placed. Then, when it is attached, the Bind button should be enabled.
I hope this will work for you.
This is normal status "loaded" and type "attached"
I guess the only workaround it's to open a new archicad bind it in it and copy paste it to the teamwork...
Thx.
I will report this to Graphisoft as a possible bug.
Istvan Moharos
Graphisoft Alumni
Graphisoft Alumni
This is a known issue. In version 18 there is no bind or similar function to explode an XREF in Teamwork because of technical reasons. We are working on this issue to find a long term solution.
As a workaround I suggest that bind the XREF in a solo PLN file and copy it back to the Teamwork project, or save the Teamwork project to PLN, bind the XREF then share the project again.
Best Regards,
István
István Moharos
Manager, Technical Services
GRAPHISOFT
