Visualization
28.1.0 Preview: 3D Window Glitch
Eduardo Rolon
With any "3D Style" that has "Shadows" on"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
6 REPLIES 6
runxel
Hero
Rather looks like you have two walls in the same position:
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
Nope. Single wall.
If you don't have shadows on there is no glitch.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Update,
Looks like moving the Sun in the 3D Window setting resets the shadow and the glitch is removed.
The original file still keeps the glitch.
AC29 US/INT -> AC08
another Moderator
Huh, interesting. So it happens only in the "shadowed" side?
Mh, I've seen similar issues with wonky graphics drivers, but you're on Mac, so that shouldn't be the problem either. Maybe send the file to the support for them to check it? šŸ˜•
Not necessarily on the shadowed side.
File sent just in case.
AC29 US/INT -> AC08
another Moderator
Batu Gezer
Graphisoft Alumni
Graphisoft Alumni
Hi Everyone,
Thanks for bringing this to our attention. we have done some background investigation, and the reason why this is happening is that the sun is parallel to these problematic walls. This is the reason why, as mentioned, moving the sun fixes the problem, as it is not directly parallel to it. :
Another solution would be to try switching to the physically based renderer, which uses shadow mapping instead of shadow volumes in this case it doesn't intersect with the shadow.
Hope this helps!
Kind regards,
Batu
Batu Gezer
Technical Support Engineer | Graphisoft SE
