‎2011-08-06
03:43 AM
‎2023-05-26
02:59 PM
Rubia Torres
‎2011-08-06 10:58 AM
‎2011-08-09 01:01 AM
beautiful wrote:unfortunately you can't use image fills as cut fills in ArchiCAD. But you can use image fills for model surface and other fills.
I found the structure/cut fill and model surface is limited.
I hope I can import the both of the item using the photo I taken from the real material to make the 3D view more realistic.
Have anyone try this one?
