2014-09-07
09:47 AM
2023-05-11
01:03 PM
Noemi Balogh
2014-09-07 06:27 PM
2014-09-07 09:05 PM
ejrolon wrote:I feel that there are dozens of reasons to stick with Artlantis - especially if you have the Studio version (vs the Render version which only does static images).
For some renderings Artlantis is faster. Besides that there is no reason
2014-12-12 01:56 AM
2017-10-30 02:29 AM
2017-10-30 12:25 PM
andyro wrote:I have been using Artlantis 6.5 with ArchiCAD very successfully. I was using the Solo version of ArchiCAD until this year, so I had no choice (no CineRender in Solo), but even with the full version I still find myself using Artlantis. MAinly because I haven't learned CineRender well yet, but I really feel that I can work very efficiently with Artlantis.
Karl, a few years later - would you still say the same as above? I am frustrated by slow cinerender renderings in Ac (yes, LW was not as good but at least it was fast) and having just downloaded a demo version of Artlantis Render 6.5 I am shocked by how slow It has become. I used to swear by it (but it's been a few years since I had to render). Now I really need to dig in and do some research because it seems my pre-assigned shaders, lights and cameras no longer cut it on import in Artlantis 6.5 (I used to get excellent OOTB results this way) - and they have changed the interface and functionality just enough to cause a steeper learning curve - enough to consider alternatives. Do you still use Artlantis regularly?
A
2017-10-30 02:07 PM
2017-10-30 05:32 PM
andyro wrote:Hi Andy,
2017-11-09 03:44 PM
2017-11-13 01:53 PM
andyro wrote:Yes, I duplicate shaders from the library and modify them as needed, this has gotten me about 95% of what I need for projects, the other 5% I typically have textures for bump and colour that are pretty self explanatory that I use. This is mostly for bricks, roof tiles and wood sidings, as I find the procedural shaders too complex to adjust.
@Erwin - Thanks for your other posts here in ACT. I realized something you said about creating new materials from the 'library' - it appears that these are not mere images in the library but complete shaders for cinerender. I will try a few out. Making progress with settings - rendering full 2000pixel wide images in under 5 minutes on a residential project, and marquee'd interiors (room by room) in under 5 minutes. Physical options OFF for speed.
