2024-06-10 11:01 PM
I have Archicad 27 Build 5030 and when i render something sometimes i have this error: Cineware by maxon add-on has unexpectedly closed.
Even with Build 3001 i had the same problem.
It's very frustrating, could someone help me please?
Operating system used: Mac Apple Silicon Sonoma 14.5
2024-10-01 08:55 PM
I have the same problem; I think Maxon is not compatible with Sequoia; only to Sonoma; I don't know why and it's frustrating
https://www.maxon.net/en/requirements/maxon-app-requirements
2024-10-07 10:43 PM
I get the same error trying to run ArchiCAD 28 in Sonoma. See screenshot
2 weeks ago
This is happening because of faulty Cineware folder in installation folder of Archicad.
You can simply replace it with one copied from someone who does not have this problem.
Not sure if this link will work
a week ago
That worked for me. Had the same problem in both AC27 and AC28
Thanks 😊
a week ago
I suggest you guys use D5 Render free and easy to use. 😎
a week ago
D5 Render is not available for macOS.
a week ago
😑 then for macOS you can try twinmotion. 😃
a week ago
After replacing the Cineware folder with the one you suggested, I get this notice when I start ArchiCAD:
a week ago
have you tried reinstalling Archicad?
